Spring Perches
71MONTE4YA
Spring Perches
Post by 71MONTE4YA »
Hey Jim!! Can I use these perches on my BOP 12 bolt rear? The previous owner that I bought the rear end from moved the perches on top of the housing to put it in a g-body regal.
Re: Spring Perches
Yes i believe you can as long as they hang off the front of the axle tube and they are NOT to high . The bottom of the spring should be even with the top of the axle tube. Jim
71MONTE4YA
Re: Spring Perches
Thank you very much Jim!!!... Rodney
Re: Spring Perches
If you can get those perches off you can even use them...Hang them off the front and put some lower support gussets and be done. :) Jim
