Spring Perches
71MONTE4YA
Spring Perches
Postby 71MONTE4YA » Thu Sep 06, 2012 4:21 pm
Hey Jim!! Can I use these perches on my BOP 12 bolt rear? The previous owner that I bought the rear end from moved the perches on top of the housing to put it in a g-body regal.
Re: Spring Perches
Postby monzaz » Thu Sep 06, 2012 8:39 pm
Yes i believe you can as long as they hang off the front of the axle tube and they are NOT to high . The bottom of the spring should be even with the top of the axle tube. Jim
71MONTE4YA
Re: Spring Perches
Postby 71MONTE4YA » Fri Sep 07, 2012 10:29 pm
Thank you very much Jim!!!... Rodney
Re: Spring Perches
Postby monzaz » Sat Sep 08, 2012 7:47 pm
If you can get those perches off you can even use them...Hang them off the front and put some lower support gussets and be done. :) Jim
