Hey Jim!! Can I use these perches on my BOP 12 bolt rear? The previous owner that I bought the rear end from moved the perches on top of the housing to put it in a g-body regal.
Yes i believe you can as long as they hang off the front of the axle tube and they are NOT to high . The bottom of the spring should be even with the top of the axle tube. Jim
