>>>>>>>>>>>>> SOLD <<<<<<<<<<<<<<
HERE IS A HARDER TO FIND GEAR RATIO -
10 BOLT 8.2 BOP
A BODY 1967 - 1972 ERA
GTO GRAND PRIX LEMANS TEMPEST SKYLARK CUTLASS T37 ETC.
3.23 RATIO ORIGINAL REUSED GM GOOD QUIET GEAR
NEW AUBURN 3 SERIES POSI UNIT
NEW BEARINGS AND SEALS
NEW UPPER CONTROL ARM BUSHINGS INSTALLED
NEW AXLE BEARINGS AND SEALS
HOUSING BLASTED AND PAINTED CHASSIS BLACK
BACKING PLATES INTACT
NOT A SHOW QUEEN HOUSING BUT CAN BE WORKED ON IF YOU DESIRE... MOST A GOOD DRIVING DIFFERENTIAL FOR SOME OFF LINE AND STILL BE ABLE HIT LONG DRIVES ON THE FREEWAY WITH OUT OVER REVVING THE MOTOR.
SOLD 3.23 pontiac 10 bolt 8.2 posi rear end A body 1967-1972 GTO GP
Re: 3.23 pontiac 10 bolt 8.2 posi rear end A body 1967-1972 GTO GP
What blemishes are on this housing? Just asking because of statement of not being show. I do not see a price listed. I have some parts to trade towards this rear assembly if that’s possible. I have another 8.2 assembly like this from a 69 Grand Prix with a 3.23 open rear. I have a set of Richmond Gears in the original packaging from the mid to late 70’s with about 7000 miles on them with adapter for carrier 3.90 ratio. I have 9 inch Ford 3rd member posi unit 3.25 ratio 28 spline.
Sorry this rear sold months ago.
We try to keep up with the ads as much as we can. The Business of building diffs is top priority. We are SWAMPED everyday.
