3.23 pontiac 10 bolt 8.2 posi rear end A body 1967-1972 GTO GP
HERE IS A HARDER TO FIND GEAR RATIO -
10 BOLT 8.2 BOP
A BODY 1967 - 1972 ERA
GTO GRAND PRIX LEMANS TEMPEST SKYLARK CUTLASS T37 ETC.
3.23 RATIO ORIGINAL REUSED GM GOOD QUIET GEAR
NEW AUBURN 3 SERIES POSI UNIT
NEW BEARINGS AND SEALS
NEW UPPER CONTROL ARM BUSHINGS INSTALLED
NEW AXLE BEARINGS AND SEALS
HOUSING BLASTED AND PAINTED CHASSIS BLACK
BACKING PLATES INTACT
NOT A SHOW QUEEN HOUSING BUT CAN BE WORKED ON IF YOU DESIRE... MOST A GOOD DRIVING DIFFERENTIAL FOR SOME OFF LINE AND STILL BE ABLE HIT LONG DRIVES ON THE FREEWAY WITH OUT OVER REVVING THE MOTOR.
