9.375 Rear end posi gears
If you want certian parts this may be the place to find them. Just ask someone may have just want you want.
Fritz
Post by Fritz »
Hi, I‘m searching for my Buick 9 3/8 posi rear end a set of internal gears. Is there something aftermarket avialable?
Greetings Fritz
Re: 9.375 Rear end posi gears
12 bolt chevy Posi side gears can be retro fit the small pinion spider gears are unique and will either need to be machined to fit from a 10 bolt Chevy 8.2 carrier and the ID machined to fit your cross shaft from your unit.
IF you need a cross shaft...OH BOY.... That is going to be a real tough one. :( Jim
