Hi, I‘m searching for my Buick 9 3/8 posi rear end a set of internal gears. Is there something aftermarket avialable?
Greetings Fritz
9.375 Rear end posi gears
Re: 9.375 Rear end posi gears
12 bolt chevy Posi side gears can be retro fit the small pinion spider gears are unique and will either need to be machined to fit from a 10 bolt Chevy 8.2 carrier and the ID machined to fit your cross shaft from your unit.
IF you need a cross shaft...OH BOY.... That is going to be a real tough one.
