ZG 3.36 rear end help
binskyhere
Post by binskyhere »
I have a 69 Firebird ZG 3.36 rear end. I’m looking for a rebuild kit for it including the axles. Any recommendations?
Thanks@!
Eddie
Re: ZG 3.36 rear end help
We have all the stuff.
10 bolt 8.2 PONTIAC
Might be a good idea to ID this rear JUST to be sure it truly is what it is.
There are really minimal rears that will fit the firebird so it should not be too bad and if the axlke tube has the ZG it really should be PONTIAC.
Will send the price via PM to you... as prices always change I do not want people 10 years down the road trying to get that same price...lol.
Now you say axles...Meaning axle shafts not axle bearings and seals?
JD
Another thing is the posi unit... safety track. After this amount of time you really should open that unit to see if the cones are getting close bottoming out or bottoming out already. Jim
binskyhere
Axle tube is ZG. Gear has 37-11 GM 68 stamped on it. (Tried to put pics on here with no luck) Here is a link to some pics in Dropbox.
https://www.dropbox.com/sh/lei6g4yicpd8 ... LGBra?dl=0
I'm looking for a rebuilt kit including gaskets, and all the parts to rebuild the axles. Unfortunately I am not familiar with the cones. If I take the unit out and apart would pictures help you determine if it is still good or do you recommend replacing the unit since it is the original one? Thanks for your help.
Eddie
Pontiac 8.2 rear for sure. We have all the parts for that rear.
Should have sealed bearings for the axle shafts.
You said you wanted NEW axle shafts complete right? Jim
to add pictures it should be as simple as ATTACHMENTS files tab below and ADD FILES will take you to your home computer browser to pick you pictures you want up...??? Y/N?
I did an example picture of a reconditioned Pontiac unit it let me do it just fine...???
