12 BOLT OLDSMOBILE O TYPE POSI UNIT ANTI SPIN CARRIER 28 SPLINE NEW
IN STOCK
12 BOLT OLDSMOBILE REAR ENDS
POSI UNITS
YUKON DURA GRIP (eaton design unit clutch and 400# preload street strip )
3 SERIES CARRIER (3.08 3.23 gm ratio and 3.42 or 3.90 aftermarket ratios)
28 SPLINE AXLES
793.00 NEW IN THE BOX
3.42 AND 3.90 GEARS ARE AVAILABLE ALSO
WE HAVE A FEW USED GEAR SETS 3.08 2.56 ETC.
PLEASE USE THE REAR DIFFERENTIAL COVER AS A REFERENCE TO WHAT THESE PARTS FIT INTO.
MASTER BEARING REBUILD KITS
AXLE SHAFTS
AXLE BEARING AND SEAL KITS.
WE CAN ALSO INSTALL EVERYTHING WE SELL IN THE AREA AKRON , OHIO
THANK YOU, J D RACE
