12 bolt CHEVY CHEVELLE MOSER HEAVY DUTY REARS BOLT IN STOCK FIT!
Post by monzaz » Mon Feb 04, 2019 4:35 pm
12 BOLT CHEVY 64-67 CHEVELLE, A-BODY, GTO, CUTLASS, GS, EL CAMINO
MOSER HOUSING HOUSING 1/4 THICK TUBING
HEAVY DUTY CENTER CASTING
HEAVY DUTY BEARING CAPS
HEAVY DUTY MACHINE BOLTS
UPPER CONTROL ARM BUSHINGS NEW
PINION YOKE NEW
YUKON LIMITED SLIP DURA GRIP POSI UNIT NEW
1541 H ALLOY YUKON AXLE SHAFTS NEW
ALL BEARING AND SEALS NEW
RING AND PINION GEARS YUKON PREMIUM 3.31 3.55 3.73 4.10 4.56 RATIO AVAILABLE FOR THIS PRICE
EVERYTHING LISTED ABOVE IS : 2425.00 + ADD SHIPPING WILL NEED ZIP CODE TO CLOSEST OLD DOMINION OR FED ED FREIGHT TERMINAL!!!
OTHER RATIOS ARE AVAILABLE UPON REQUEST AND PRICED SLIGHTLY HIGHER
AS PICTURED -
OTHER OPTIONS -
1350 YOKE
ALUMINUM RACE GIRDLE COVER
DRUM BACKING PLATES
DRUM BRAKES
DISC BRAKES
RACE SPOOL
RACE AXLES BOLT IN STYLE
THANK YOU, J D RACE
JIM MITSCHKE
AKRON, OHIO
330 990 8155
