2 wd s-10 8.5 heavy duty 3.73 posi rear all built new
10 bolt 8.5 s-10 2wd Heavy duty rear
3.73 ratio
HIGH performance posi unit 30 spline
NEW 30 spline GM AXLES
ALL NEW BEARINGS AND SEALS
DIRECT BOLT INTO ANY 2WD S-10
1550.00
WITH ANY 7.5 TO 8.5 SWAPS YOU WILL NEED A SHORTER DRIVE SHAFT BY ABOUT 1" BIGGER REAR THIS IS A NORMAL OPERATIONS NOW WAY AROUND IT.
AKRON, OH
