More pics Jim here is my pattern, Help!
Lasttime78
Post by Lasttime78 »
What is a good shim thickness to start out with on the pinion in a 7.5 10 bolt.
Re: Starting point for Pinion shims?
The stock one under the original gear set.
.030 -.035 some where in there.
Run the pattern around and around bunches of time you have to be sure the pattern is correct.
Lasttime78
Here is my pattern, Help!
Hey Jim, This is Jim as well This is what I have right now. I am starting out with a .24 pinion shim. I believe the back lash is 4-5 thousands.. :?
Lasttime78
more pics
Lasttime78
Re: here is my pattern, Help!
Some more pics of same pinion shim differant shim stack on carier though.
First off you have to keep the backlash close to the proper distance to check the pattern .002 .003 is JUST too tight. You need to check at .008 -.010
From what I can see the pattern shows too shallow. You will get noise. Try not to use a flash on the pictures just light the gears good and use NO FLASH. Jim
You said on the phone you had .020 for the pinion
HAve to have more backlash. to make sure remove more from driver side and add to pass side. Jim
Lasttime78
I can do that I will post more pics in about a half hour. Thanks Jim
I just want to be sure you have it right. Jim
Lasttime78
Oredered more shims here is a couple differant set-up and have the numbers to. Then maybe we can figure out which way to go. shim was 32, backlash 7-8, carrier shims lft.210 rght.259
one set up 1an2 pics
Lasttime78
2nd set up. pinion shim 37,6-7 backlash,lft carrier shims 222,rght.249
Lasttime78
3rd set up. pinion shim 39, 7-8 backlask,lft carrier 222,rght.249
Lasttime78
4th set up. pinion shim 36, backlash 8-9, lft carrier shims 219,rght.251
Re: More pics Jim here is my pattern, Help!
PLease let me know what you did to the last 4 pictures ?
All you needed to do was open up the backlash...OR is this what it looks like after opening up the backlash at .020 pinion shim?
I need numbers to help you. Jim
Lasttime78
this is final as of right now. 35 on pinion, 6-7 backlash, lft carrier shim 224, rght side 248. Ready to button up!!!!!! must have pulled and reset over 75 times.
WOW just hate it... The .020 was the best in all the pictures so far. I can not believe that a .030 shim will end up being the correct shim...??? From all the pictures
ARE you sure your shims are sitting flat and flush on the pinion stem they should not be climbing / bending up ward on the center of the doughnut of the shim. Jim
GOD - Did you ever take pictures of the .030 -.025 shim? with .008 backlash? Jim
