1969 buick 8.2
LBROUSS77
1969 buick 8.2
Post by LBROUSS77 »
I have a 69 buick rear axle 8.2. axles are bolt in with 28 spline. pinion is 27 spline. I would like to replace all bearings, races, and seals. and put 3.73 gears in it. The spider gear pin also broke so I would need one of those. The problem I am having is the differentail bearings are different sizes. Everyone is telling me parts are no longer available for these particular rear ends. So can anyone prove them wrong?? please help or does anyone have a complete unit that would be compatible, basically bolt right up is what I am saying. thanks to anyone who takes the time to answer.
Re: 1969 buick 8.2
Well you do have a dilemma here...
1968-1970 10 bolt Buick rears are a different beast for sure.
There are NO 3.73 gears for this rear. we do have 3.42 or 3.64 ratios
Posi carrier is also available too.
Bearing kits are also available through us too.
Just a expensive rear to build.
3.42 or 3.64 gears are 459.00 NEW and are totally USA custom made for the 68-70 buick through Fabcraft Metalworks in TX.
Posi unit is a Auburn and that would run 439.00
Rebuild kit for the rear is 95.00
Axle bearing and seal kit is 69.00 for the NON GS models.
Axle bearing kit for the 68 69 GS ONLY is a whopping 175.00 for the pair of bearings. :( YUCK O for the GS owner in 68 69. 70 is ok as they used the same bearings as the regular skylark non GS
NOW for the GOOD NEWS... You can use any BUICK OLDS or Pontiac A-Body 10 bolt 8.2 from 1967-1972 direct bolt in
You can use any 1968-1972 Chevy A-body El camino, Monte carlo, Chevelle... Just need a u-joint swap about a 25.00 optional swap.
So I hope some of this info helps.
We also can build you any of the rears listed too.
Parts for your 1968 skylark Buick rear are instock and ready to ship if you decide to go that route.
JD
