1966 Pontiac B-Body Catalina 2+2 need a posi...
Ragtop Man
Actually, really just WANT one to lay down two black stripes. 99% sure it is the standard, factory 3.23 open diff. Which posi unit is the right one, and how well does the factory R+P hold up after all these years. BTW, trans is an automatic if it matters, thanks!
Re: 1966 Pontiac B-Body Catalina 2+2 need a posi...
Age of ring and pinion does not really make a difference as long as oil was kept in the rear and it was maintained it will out last almost ALL the parts of the car.
It will hold well IF you are installing a posi I would go for a total bearing rebuild kit to freshen the rear especially if you think you are going to be a bit hard on the rear for a while.
We have 3.55 gears for this rear too. They are expensive BUT are available.
Best way to be sure what carrier you need is to PULL the old one (open ) measure the ring flange offset and let us know will see what we have in stock. it will either be 2" or 2 3/16"
Measure it like the picture
