8.5 identification
Clint Hester
8.5 identification
Ive got an 8.5 rearend under my 80 malibu. It was supposedly a G-body 8.5 out of a hurst olds but it has the 4-bolt backing flange on the tube ends. Possibly someone changed the flange im not sure. Is there any way to i.d. it using a casting number and where might that number be located? Thanks
Re: 8.5 identification
Yes NOT likely it is a STOCK GN /442 hurst olds 8.5 rear IF you post a few pictures of the rear cover area, spring perch area, lower and upper control mounting area too.
The GN/442 10 bolt 8.5 will have a 2.5 " tube diameter same as the 7.5 10 bolt tube. ALL other 8.5 10 bolt rears have 3" tube diameter.
Casting numbers elude me at this time ...
Clint Hester
Ill get some posted the weekend thanks
Clint Hester
sorry for the delay
Clint Hester
Looks almost stock I have to see close ups of the weld. Any way That is a STOCK GN /442 8.5 rear Just have to see if someone welded ends on it . Jim
Definitely 8.5 and definitely G-body
Need close ups of the flange area where the backing plates bolt on.
