g-body rearend swap
Clint Hester
g-body rearend swap
Post by Clint Hester » Fri Apr 17, 2009 9:54 am
Just trying to find some info on putting a 72 monte carlo 10 bolt under my 78 Malibu. Is this a bolt in type thing using different UC arms and offset wheels? I know you can do this swap using the 68-72 chevelle rear but dont know much about the monte carlos rear. Is it the same width and mounting locations as the chevelle. Any info would be appreciated as im doing this swap and a couple more in the near future on my 85 regal and 86 cutlass. Thanks Clint
Re: g-body rearend swap
Post by monzaz » Fri Apr 17, 2009 8:58 pm
Clint, Yes the monte carlo from 1970 -1972 are the same as 1968-1972 chevelle and elcamino and all the A-body rears of this era.
Yes the upper controls are are one of the main swap mod items that will be needed. we carry them for 145.00 + the ride.
Next the mod would be the spring perch mounts centered on the axle tube tops.
The lower control arm pockets will be close but could be an issue. the shock stud will be at a slightly different angle and could need so adjusting also.
NOW obviously this will all depend on how well you want this rear to work and what you expect it to ride like. Remember this will not ride like the original rear did because it was never design to fit the application. It is a cheaper way to get a better rear under the car.
J D Race.com does sell many versions of htis rear at a lower cost than a Moser or Currie or Strange using used parts from other differential to make one rear stronger than a 7.5 easy. All the mounting points will be as stock except for the upper...YOU will still need the upper control arms to get the suspension to travel properly and true.
The lower and spring perch and brakes etc will all bolt right up like stock. All the mounts are GM original components. Please check http://www.jdrace.com front page and click the new product in the NEWS section...it will take you to all the new products section.
We also offer HOUSING AND AXLE PACKAGES TOO...
Good luck on the choice of the rear. we will always be here to help in what ever you choose. Jim
