Differential Yoke
Differential Yoke
The yoke on my 67 GS400 is leaking. Is there a way to fix it? I can't seem to find one.
Re: Differential Yoke
Ok, well first we need to inspect the yoke seal area then the seal. Sometimes the fluid can leak from the spline area and Buick had a 'O' ring just under the yoke end to control this. It maybe distored or missing also.
We also need to make sure we are dealing with the rear you say it is also. Pictures are great here. rear cover area with surrounding casting helps ID the rear
Do you have the yoke area disassembled?
If you do please provide pictures after you get the area as clean as you can dissassembled. I have the correct seal and I also have good used yokes also if you need one.
If you have to call an discuss we can do that also. Just ask for a number and will get it taken care of. Jim
Thanks for the info. It's not apart yet, but when it is I'll let you know.
Yes Jim, I would like your number because once we get it apart and figure out what I have, I'll need to get parts as soon as possible. Thanks.monzaz wrote:Ok, well first we need to inspect the yoke seal area then the seal. Sometimes the fluid can leak from the spline area and Buick had a 'O' ring just under the yoke end to control this. It maybe distored or missing also.
Oh man, sorry for the delay on this... 216 464 2313 x240 weekdays 10 -4 eastern standard time. Jim
If you can put up some pictures of the rear and or the yoke and its seal area. I can get you the parts you need. Jim
