in the proses of redoing my grandmothers 94 caprice and am looking for a good street/strip posi/limited slip unit. that is rebuild-able and has somewhat quiet operation.
more street then strip of course. but want both wheels to grab when needed. thanks
94 caprice 8.5 posi unit suggestions wanted
dustin3207
Re: 94 caprice 8.5 posi unit suggestions wanted
There are many good options
We have Nitro gear and axles posi unit which is just as a EATON clutch type unit with 400# preload clutch springs that will give you the best street and strip action your looking for
Hardened spiders for strength and long life.
Carbon Fiber clutches for great hook and smooth operation in turns.
419.00 12.00 shipping to all 50 states
Will fit all 1990-1996 GM Caprice and or Impala Roadmaster 8.5 rear ends.
Rebuild kit is 79.00 with purchase if a Posi unit
We also have gears from 3.08 3.23 3.42 3.73 3.90 4.10 4.56 4.88 and beyond.
Jim PM or call if you need any thing.
dustin3207
does the rebuild kit come with outer bearings and seals?
outer bearings and seals...?? Axle /wheel bearings and seals...If this is what you mean... No they are sold separately as there are many different wheel bearing and seal options for rears .
1994 caprice should be 30.00 for 2 seals and 2 bearings that will do both sides for you.
If you have a wagon then they are 45.00 for the pair.
