Hello I have a 1970 Buick GS455 it has a pois rear end with a 2.93 ratio. I was hoping to be able to go to a 3.73 or equal ratio. I have checked the bolt heads on the carrier they are 3/4. I am about to have the frame and a few other things powder coated and was going to send the rear end housing too. I just wanted to make sure I could change the ratio and rebuild the rear end I have before it was powder coated. Or would it be cheaper for me to start with an 8.5 rear end.
Thanks Corey
Buick 8.2 questions
Re: Buick 8.2 questions
Cory, We really would prefer to SEE the rear diff you are working on. IF it is a STOCK 1970 it should be a 10 bolt 8.2 BUICK ONLY rear.
We have after market 3.64 gears for your ORIGINAL 8.2 1970 they are 459.00 a set.
YOu would need a spacer to use the carrier you have in the rear right now. OR get a new carrier that we also have. 419.00
The 8.5 will be slightly cheaper as the gears are less - BUT if you have to pay for a core 8.5 rear to build (100.00 -300.00 depending how lucky you are on craig's or junk yards) you will be close to the same price by the end of the build.
Nothing wrong with either 10 bolt both will performance every well on the street and even track time.
MAke sure you or someone else set-up the rear correct and they will both take plenty of power.
Post some pictures and will ID the rear just so you know what your starting with.
The pinion spline is 27 and the right side carrier bearing is larger than the left side.The ring gear bolts also have L on them. I have attached some pictures below.
Thanks Corey
Thanks Corey
Yep, That is the 68-70 8.2 buick. Looks like that posi is going to need some cleaning and disassembling. Very dirty with rust, mud or something...lol.
You have left hand thread 7/16" bolts so watch and remember when removing opposite of normal tight and loosening.
Carrier bearing on the driver side is a 12 bolt chevy carrier bearing and race A36set
carrier bearing on the passenger side is normal 10 bolt 8.2 of the rest of the GM units.
All this info is in the ID differential section of this forum. Gives you ALL the bearing numbers and carrier break etc.
There are PLENTY of people out there looking for a 2.93 posi rear for a good driving car. Great ratio for all around performance.
Might want to clean it all up tear that posi down (or we can recondition it for you minimum price 50.00 max price 150.00 ) clean everything with kerosene put some seals in inspect all the bearings and reassemble this and sell to support the 8.5 10 bolt build. Or WE can definitely sell you all the parts to put this rear together to hold the power of the 455 engine. The aftermarket gears we sell will be way stronger than your GM gears and the posi unit will also be a huge improvement . Jim
Jim what would I was trying to figure out what it would cost me to chage the ratio and rebuild the posi carrier and replace the bearing in the differential. I would like to go with a 3.73 ratio.
Thanks Corey
Thanks Corey
monzaz wrote:Cory, We really would prefer to SEE the rear diff you are working on. IF it is a STOCK 1970 it should be a 10 bolt 8.2 BUICK ONLY rear.
I gave you an idea already with prices of the gears (459.00)and posi (419.00) -no 3.73 are available for the rear you have only 3.64. Rebuild kit is 100.00 for the bearing kit that would include ALL the parts (shims ring gear bolts bearings races gasket crush sleeve pinion seal and nut...) needed to install the posi and the gears. Axle bearings are 69.00 for the late 69 and 70 oiled bearings A9 712146 seal and if you have a 1968 or 1969 early you will have big money in bearings IF you can find them. RW507GR bearings go from 50-150.00 EACH. seals are still available.
Labor to set up for us is about 200.00 normally 150.00 -400.00 in other companies -
Might want to clean it all up tear that posi down (or we can recondition it for you minimum price 50.00 max price 150.00 ) clean everything with kerosene put some seals in inspect all the bearings and reassemble this and sell to support the 8.5 10 bolt build. Or WE can definitely sell you all the parts to put this rear together to hold the power of the 455 engine. The aftermarket gears we sell will be way stronger than your GM gears and the posi unit will also be a huge improvement . Jim[/quote]
Here is the quote on the rebuild of your posi -
Thanks for getting me the prices for the rebuild. I had one more question about my posi unit. Would I be able to use my carrier with the 3.64 gear with the use of a spacer. What would be the prefered method a bigger carrier or spacer and what would a spacer and bolts cost?
Yes sir- You can do that no problem. JUST make sure you use a GOOD complete kit with the correct LONGER bolts to take up the spacer width.
JIm
