Hi all,
I need to ID my 10bolt belived to be a BOP rear.
The stamp code on the axle tube is: SS B117 1 (really need to decifer this)
The gearing is 3.23:1 and is a positraction Eaton style carrier.
There are other identifiers casted into the center section like the letter "A" in three places, "CFD", "1235197", "11" and a date code "110"
The wheel cylinders have on them "2940" and "15/16". The axles are bolted in type and 28 splined. The cover has a stamped number "1234496". The distance between the flanges are approx 54-1/2"
This came off my donor 67 Chevelle any info on this will be helpful thanks in advance.
Rob
Need Help Identifying This 10 Bolt
Re: Need Help Identifying This 10 Bolt
Can you shoot some pictures of the housing.
Also what kind of bolts are used to hold the u-joint in place ? u-bolts and nuts or 4 straight bolts and 2 straps?
Just looked in my personal casting book...It is a 10 bolt 8.5 rear it has a ROUND cover like chevy but it is different with only 1/2 the oil trough to the right up part of the cover.
it has 4 bolts and 2 strap u-joint retention and a 1 1/4" nut that hold the yoke in place.
The rear is really from 1971 1972 oldsmobile.
So there you have it. This is a keeper and will handle plenty of horses.
Reason: add pictures
