Hello,
I am looking for a Positrac, 3.08 gear and pinion set, and required bearings, clips, etc. to convert a factory non posi 2.56 gear rear differential on a 1970 Olds Cutlass S with the O type factory axle and diff. 12 bolt diff cover.
Thanks for any help that you all can provide.
1970 Olds O axle posi trac and 3.08 gears
Re: 1970 Olds O axle posi trac and 3.08 gears
Are you the same that called?
We are checking a few housing that might have gear set in them. ONLY way you can get 2.56 2.78 3.08 or 3.23 are good used or OEM found in a OLD dealer ship. Jim
Good morning, yes I am the same guy that called. Thank you for looking for the gears.
pretty sure we have a set. I just have to evaluate them for a price. 3.08 and 3.23 are getting hard to get, never cheap.
Sounds good, I’m excited to get some gears to help motivate the car.
