sold 10 bolt 8.5 Buick 1972 Skylark Oldsmobile cutlass 1971 POSI 3.73
-------------------- SOLD --------------------
NEW BUILD
10 BOLT 8.5
1971 1972 A BODY SKYLARK OR CUTLASS GM HOUSING
NEW TRUE TRAC POSI
NEW 3.73 YUKON RING AND PINION BRAND
NEW BEARINGS AND SEAL
NEW UPPER CONTROL ARM BUSHINGS
AXLES ARE BOLT IN AXLES
ORIGINAL AXLES WITH ORIGINAL BEARINGS AND SEALS
BACKING PLATES INCLUDED
HOUSING BLASTED AND PAINTED CHASSIS SEMI GLOSS PAINT.
WILL FIT ALL GM A BODY CHASSIS FROM 1968-1972 AND 1964 - 1967 WILL BE 1/2" WIDER ON EACH SIDE.
1975.00
SHIPPING IOS AVAILABLE - NEED A ZIP CODE TO FIGURE THE CLOSEST TRUCK SHIPPING TERMINAL FEDEX FREIGHT OR OLD DOMINION
AKRON OHIO
