10 bolt 8.5 and 8.625 posi unit gears and rebuild kits LIMITED TIME!!!
ALL PARTS ARE NEW IN BOXES
10 bolt 8.5 and 8.6 LSD POSI UNITS
EATON YUKON
28 OR 30 SPLINE
400# PRELOAD SPRING
PERFORMANCE CLUTCHES STRONG AND QUIET OPERATION
ALLOY HARDENED SPIDER GEARS STRENGTH TO HANDLE THE TORQUE
NEW IN THE BOX - 359.00
GEARS-
YUKON PREMIUM RING AND PINION SETS
3.23 3.42 3.73 3.90 4.10 (164.00 A SET)
4.56 4.88 5.13 5.38 -(LIMITED QUANTITIES) (149.00 A SET WILL MAKE MULTIPLE GEAR PURCHASE DEALS WITH STEEP GEARS)
MASTER REBUILD KITS
8.5 ( 28 OR 30 SPLINE 1971 - 1999 ERA )75.00
8.6 (30 SPLINE 1999 - 2017 STANDARD BEARING INNER AND OUTER) 82 .00
8.6 (30 SPLINE 2009-2018 SPECIAL 4X4 PINION BEARING KOYO ONLY BEARING ) CALL FOR PRICING
SHIPPING
WILL NEED YOUR ZIP ODE AND LIST OF ITEMS SO WE CAN FIGURE THE WEIGHT AND WILL GET YOU A PRICE ASAP.
THANK YOU, J D RACE
!!!!! PRICING FOR A LIMITED TIME BEFORE HOLIDAY SPECIAL !!!!!
