dana 60 complete B-Body rear 68 69 mopar hemi
Here is a CUSTOM BUILT DANA 60 rear end built with 3.54 gears, traction Lock posi, All new bearing and seals, Moser race axles 35 spline 11" performance drum brakes all new parts Lines and brake hose also included.
500.00 in MOPAR MADDNESS 11" HEMI drum brake parts
Spring perch center line 44"
over all width is 58.5 " slightly narrower than the stock 68 69 B-body so you can fit the big meats under the car.
Shipping is available if needed - Just ask for a quote, will need a zip code.
2445.00 as pictured
