All kinds of POSI UNITS dispaly models DEALS!
Posi units GALORE!!!
Dana 60 Detroit lockers 30 spline and 35 spline low series will hold 3.54 3.73 4.10 and thick 4.56-6.14 ratios 495.00 each
Dana 60 TRUE TRAC posi holds steep gears only 4.56-6.14 ratios 495.00
10 bolt 7.5 True Trac posi 340.00 1975-1989
GM reconditioned 2 series posi unit 229.00 1975-1989
Gm reconditioned 7.625 posi 239.00 1990-2004
8.5 10 bolt AUBURN HP 30 spline posi 299.00 1990-1998 (truck or car)
8.625 10 bolt Auburn HP 30 Spline posi 349.00 1999 - 2015 (newer larger bearing 10 bolt GM truck SUV cadillac)
Dodge 12 bolt 9.25 1/2 truck muscle car rear end eaton posi 31 spline c-clip 365.00
YOU will only find these prices on J D Race.com and must be referenced to get the price.
ALL units were display NO BOX items that are still new and never installed in a vehicle
Some will have bearings or ring gear mounted and or removed and some cosmetic scratches etc.
Please ask questions about fitment if you are unsure send a picture of the rear diff your working on will ID it and see if we have your item on the shelf.
Thank you, J D Race
