Hello from New Zealand
Come on in. Welcome to JD Race forums. Please come on and introduce your self, Let us know what your ride is. Please enjoy the site!! Please no questions. There is a seperate section for that. Thanks much.
muzzy
Post by muzzy »
HI, New user from NZ,rebuilding the rear axle on my 69 Camaro with ring & pinion I got form Jim.
Hoping to get some advice regarding reassembly, gear pattern and condition of the clutch pack in the posi.
Regards Muzzy
Re: Hello from New Zealand
Muzzy good to see you here and hoping to help you and other understand more of building the rear differential parts with and with out proper tools.
Make sure to use the differential section to ask the questions. :) Jim
muzzy
Post by muzzy »
Yep,sure will Jim,I will have to learn to post pics
Pretty easy on this sight. Upload Attachment (under the subject WINDOW highlighted in grey) will get it done and you can browse your computer for the picture select the picture and it will be saved on this site. IF you want up loads to go quicker resize your pictures to web size... Your camera or phone should have a setting to do this also LESS resolution and or pixels. Ok? Jim
