Right and Left axles, same length?
Singleton
Post by Singleton »
71 Buick Skylark 8.5 rear. Was going to pull one axle to take measurements to send to Moser. Are both axles the same, or is one longer than the other?
Re: Right and Left axles, same length?
Same length- 29 3.4" long. Sure you do not want us to take care of the order for you?
We have all the specs invoice through Moser and can probably cut shipping cost... are you doing 30 spine or 28 spline stock?
What carrier are you using? posi eaton true trac stock?
Singleton
Post by Singleton »
Thanks for the reply. I'll haven't ordered the axles from Moser, but if/when I do, I'll get with you on it.
The rear is one I bought from you last year, 28 spline, Detroit Locker, 3.90.
Tony
i HERE FOR YOU. jIM
