Torsen posi unit
billytbass26
- Rookie Poster
Torsen posi unit
Looking for a Torsen posi unit for a gm 7.5 ten bolt. 28 spline. Had one in a gm differential I purchased from jd racing and was a great unit. Looking to upgrade from current auburn with 3.23 ratio.
Re: Torsen posi unit
2000-2002 camaro and T/A LS1 motored cars will have them. Best if you save up and get a new one as the ones that are out there are getting all used up form the LS1 powered engines.
I will keep my eyes peeled for one for you at the meets. Jim
billytbass26
- Rookie Poster
Found out more about the differential. actually need 26 spline, 2 series. Im not sure those are even made. and its a 2.93 gear in the differential. I was told wrong when I purchased the car.
Apologies
Apologies
We can get you a NEW true trac for your car if you like. Jim
NO torsen 26 spline posi only 28 spline.
billytbass26
- Rookie Poster
How much do those go for? I think you mentioned somewhere that these are better quality than auburn and eaton units. I have a 28 spline auburn if your interested in a partial trade. I know it's not worth much but I believe it's in good shape. I got it from dans gears on eBay.
I do not have a torsen posi in stock. I can only get NEW true trac posi units. Or eaton is a good choice too. Jim
