spider gears
mjol
spider gears
Post by mjol »
Hello Jim.
Can I use the spider gear thrust washers [small spiders ] off an 8.2 open carrier on an 8.5 posi??
I am preping an 8.5 # 409 carrier and found these thrust washers missing.. If not , how much do you want for just the small thrust washers with shipping to 92584 ??
Thanks, Mike
Re: spider gears
No the diameter for the inner cross pins are different. You can use 8.5 OPEN differential thrust washers to do the job just not 8.2 10 bolt.
7.50 will get you 2 thrust washers and shipping to CA
