Hey there,I've totally smashed the 10 bolt in my 1970 Pontiac GT-37,(same as GTO)a mate of mine has a complete drum to drum 10 bolt from his 70 El Camino,could you tell me please if this unit will bolt straight up to my Ponty.
Cheers
El Camino 10 bolt into 70 Pontiac
Re: El Camino 10 bolt into 70 Pontiac
The entire rear will bolt right into the chassis. Only thing you might need...is a u-joint. to convert the drive shaft to the rear end yoke.
Part numbers are - conversion joint precision 372 / neapco 3-3130 / spicer 5-3022X
You should not need anything else. brakes will be the same except for the drum pilot hole chevy has a 2.81 while the pontiac has 2.771.
That should do it.
Guts are different and need to stay with there original housings.
That should do it.
Thanx heaps for that,I'll have to see if those parts are available in NZ
I am sure they are. It is called a chevy to BOP conversion u-joint.
If you can not get it PM me will ship it over no problem.
