1972 GTO with a mystery 10bolt.
leelanaumotorsports
Post by leelanaumotorsports »
I have what has truned out until now to be a numbers matching GTO.
400, 4sp M-20, PHS documented.
It has a smooth ( no ribs or indents) 12 inspection bolt cover,
inside is a B.O.P. style ( to my knowledge) Limited slip 10bolt main...41 tooth, 12 tooth pinion.
the housing does appear to be B.O.P. with two forward webs parallel. and a flat bottom at the rear.
on the passenger side rear tube is a stamping T M
on the housing between the webs is a casting 402227
on the front passenger side of the tube is a stamping CFD.
I am lost as to what this is, and if it is even correct B.O.P for a lemans /GTO let alone for this car any help would be great
Re: 1972 GTO with a mystery 10bolt.
Well pictures are always best BUT what you have described is a 12 bolt 'O' Type (Oldsmobile ) rear end
It has 12 bolt smooth cover 10 bolt ring gear. IF you look in our ID Differential tab to the left of the screen you will find ALL the details on this rear end -
402227 is the casting most likely from a 1970 This rear was produced from 1967-1970 ONLY so I am sure this is NOT the original rear for a 1972 GTO. Which it seems we already know. :(
NOW that being said it is NOT all bad as this is a great street strip Muscle car rear and ratio. 12 - 41 3.42 ratio
The carrier should be a Limited slip unit (posi) with a 'S' spring preload spring and square tab clutches as pictured below.
