WTB Rear axle bearing, retainer and seal for BOP 8.875
MikeMike123
Post by MikeMike123 »
Hi,
Does anyone have a source for the rear axle bearing, the retainer ring and rear axle seal for a 69 Pontiac Catalina Wagon. It has 31 spline bolt in axles and the seal goes into the housing followed by the retainer and bearing pressed on the axle. It is a sealed bearing. The ID is around 1.531 and OD is around 3.062. Bearing that came out were shot so dimension might be off a .001 or 2.
Mike
Re: WTB Rear axle bearing, retainer and seal for BOP 8.875
I have one coming in. Not cheap but will have one. Jim
