Help identifying GM differential
radio747
Post by radio747 »
I picked up a differential at DVAP which said it was from a 70 Chevelle. It has the casting number 1385724, which sounds like a Buick or Oldsmobile. The pinion # is 1231463, and the gear ratio is 2.73(we think). I need to change the gear ratio to high 3's to 4.1. Can I get there from here? What gears are available?
Steve
Re: Help identifying GM differential
Hello glad to see you using the site...
Off we go-
This is a 1968-1970 BUICK SKylark rear differential
10 bolt 8.2 Ring gear
Pinion shaft is 1.875
Pinion spline is 27
Gear ratios available are 3.42 and 3.64 AFTERMARKET Fab Craft / and J d Race sell them (459.00 a set They are machined by Richmond gear engineered By Fabcraft Metal works)
Posi units are custom modified By J D Race 439.00 Auburn units
Rebuild kits are 95.00 (included everything to install the posi and gears / Bolts bearings races shims marking compound inspection cover gasket, pinion seal Pinion crush sleeve, Pinion nut etc. EVERYTHING...)
Steeper gears are only available if you FIND THEM in a rear like 3.91.
If you need a steeper ratio it might be a better plan to find a Chevy 10 bolt or Pontiac or 8.5 10 bolt - Obviously 12 bolt chevy will have steep gears and most selection.
J D
radio747
Post by radio747 »
Thanks for the quick reply. This rear end has 2.73 gears. I spoke with Brad with fabcraft. He said I might need a new carrier for the 3.64 gears. Is that true? How much more is that.
Steve
All the prices are posted for you Posi gears and rebuild kit in the previous post . :) Jim
