Buick rearend question
mnicosia23
Hows it going? I have a 1968 Buick GS 350 with the 10 bolt 8.2, I was wondering what rear end I could swap into it with little to no modification. I know some need a different U Joint..I would really prefer to have posi and gears in the 3.42 range. Thanks for any and all help.
Re: Buick rearend question
Ok 68-70 Buick was its own rear - There are really NO interchangeable INNER parts for the rear from other 10 bolt 8.2 GM rears. (with out drilling or machining etc.)
We at JD Race do sell 3.42 and 3.64 gears for this rear and Positractions to go into it also
On to swap in complete rears.
Any 1967-1972 Pontiac (GTO, LeMans, Tempest, Grand Prix)10 bolt 8.2 will be a direct bolt in (literally you will need to do NO extra mods to the rear swap. NOT EVEN A U-JOINT.
Any 1968-1972 Chevy (Monte Carlo, Chevelle, Malibu, El Camino) 10 bolt 8.2 will be a direct bolt in...(all that needs to be done is a u-joint BOP to Chevy conversion joint)
Any 12 bolt Olds rear (1967-1970) from 442 and some GTOs will also be a COMPLETE DIRECT bolt in with absolutely NO mods - Not even a u-joint again.
!2 bolt Chevy 1968-1972 again a direct bolt in - IF you get one from a Canadian built Buick Olds or Pontiac and it is a DIRECT no joint bolt in. IF you get it from a Chevy you will need a u-joint BOP to Chevy conversion u-joint once again.
Even the 1964-1967 narrower BOP and Chevy rears WILL bolt into your car being only 1 inch over all narrower that is only a 1/2inch on each side.
THAT should cover it.
JIm
mnicosia23
Cant thank you enough man excellent help, now I just need to find a budget rearend haha
No Problem...Keep the questions coming as it will just help others when they google search for answers. Take care, Jim Mitschke - J D Race
