do eaton 12 bolt and 8.5 rears share spider gears?
Posted: Thu Jul 27, 2006 10:35 am
by tlowe
looking at rebuilding a 12 bolt eaton. i am having a hard time finding parts for the internals. does the eaton 8.5 share the same internals? thanks tom
spider gears
Posted: Wed Nov 22, 2006 2:02 am
Hi Tom, aftermarket maybe... but not factory. all factory 8.5 410409 and 410408 are trac lok type posi units and have totally different clutch paks and spider gears.
Eaton well now I will have to try them and get back to you.
Areas of consern. pinion shaft diameter???
Side gears might be the same but the small spider gears??? I do not know. I will check over the holidays to see. GOOD question. Like them cause I get to learn new things also.c Jim.
