1970 delta 88 rear end interchange
Posted: Fri Oct 31, 2025 11:40 am
by Delta88bill
I have a 1970 delta 88 and I know that parts are hard to come by for these things does anyone know of mostly bolt in swap out of something else that has a better aftermarket support
Re: 1970 delta 88 rear end interchange
Posted: Thu Nov 06, 2025 11:20 pm
Nothing that will direct swap.
It is all custom
9" is usually what you would need to use and get all your brackets from your old rear and cut them off and reweld to the 9" housing same with the upper ears you can get those from Speedway and weld them on too. ...It is really the only way that will be best solution.
Or keep looking for parts
all these full size cars just were not supported by the aftermarket world in 1965-1970 era. At least in 1971 - 1976 you had the 8.5 you could buy parts for.
