1975-Specific 7.5 5 lug swap questions
Posted: Thu Mar 06, 2025 5:06 am
Hey! New here, have a few questions. Okay, a LOT of questions...
I have a bone stock 1975 Monza CA 350. Right now the rear axle is the typical 7.5" 4 lug 2.29 open diff.
I'm going to be building it up to street/strip, converting to 5x4.75 using Aerospace rear disks and S10 spec Moser axles, but there's a few things I want to be sure of before I pull the trigger.
The car is going to be a built 350 and eventually get a stock LS1 as its end-game motor so it won’t need to hold more than that, at least on this axle
So, right now my parts list is:
Quick Performance package set (4.11 gears, Truetrac posi, 28 spline, solid pinion spacer, 1981 and Older 7.5)
https://www.quickperformance.com/GM-75- ... 22625.html
Moser A102807 S10 28 spline C clip
https://www.moserengineering.com/a10280 ... 0-2wd.item
Aerospace Rear Drag Brake kit (with lines and master cylinder)
https://shop.aerospacecomponents.com/re ... 1-1-1.aspx
misc rebuild parts (anyone know a good kit for these?)
Questions:
1) I have $1000ish set aside for all the setup and machine work, is it recommended to machine the housing for an S10 bearing instead of the conversion bearing (and what's the real part number for the conversion bearing? all my usual sources are way out of date)
2) Will it hold the 400 MAX HP with 4.11s on the street and occasional strip with an automatic? I've seen both. Will be on 235 radials, but probably sitting closer to 300hp (leaving headroom)
3) Any recommended tricks for building? I.e. I've heard 4.11s over 4.10s because the 7.5 pinion is tiny and the H body has a different spline count? Stuff like that that you wouldn't know from googling.
The budget is currently $3,000 including the 1k setup, is that doable nowadays?
Am I forgetting anything? Please link me if so.
Questions:
