1964 Cutlass "Frankenstein Build" is Alive but Idle drops with Custom Cam
Posted: Thu Jul 21, 2022 3:01 am
Yes. Frankenstein is alive and runs, i did approx. 600 Miles and now there is something i would like to sort.
Facts First:
Engine: 1964 Oldsmobile 330Cui (Now Bored Up to 350 Cui)
Heads: Olds 7A (1972 / 64cc)
Compression: 10.66 : 1
Pistons: Seald Power L2320F
Lifters: Elgin Hydraulic Flat Tappet Lifters
Push Rods: Comp Cams
Cam Specs: Dur@050 Int.224 / Exh 236, Lift Int. 504 / Exh. 512, 112 Lobe Separation, 45 Degree BANK ANGLE
Carburetor: Edelbrock AVS2 (1906) 650 CFM (+ Tuning Additional 0.04" Holes on all 4 Throttle Pates)
Intake: Edelbrock 2711 (Olds 350 Performer) + 1 x Adapter Plate
Vaccum Canister: by Comp Cams
Power Breaks with Dual Master Cylinder (all 4 Wheels / Drum Brakes)
Rockers: Harland Sharp Rockers (S50062A)
Lifters: Elgin HL1951S Hydraulic Lifters
Exhaustmainfolds: Thornton's Small Block JR Exhaust Manifolds
Exhaust: 2x 2.5" Dual (Left & Right/ No X-Pipe)
Transmission: TH350 Heavy Duty Build (Alto Parts, + Shift Kit)
Torque Converter: Assault Racing 3200 - 3500 Stall (Boss Hog)
Vehicle Weight: 1424 Kg / 3140 lbs
Rear End: 1964 Oldsmobile Cutlass, Typ: P 3.08 (3.08 Ratio)
Tire Size: 205 / 70 – R14
Timing:
I got the timing Set as following.
Base Timing (Setting without Vaccum Advance): 15 Degree @ 1200 RPM
If i connect the Vacuum (Point Distributor), i have 34 Degree @ 1200 Rpm
Problem:
My problem is that i have a Idle Drop from approx 1000 Rpm Idle
to 400. It not possible to adjust the Idle (with Vacuum Advance Connected)
between 1000 Rpm and 400 Rpm. i would love to have approx. 700 Rpm in Gear at a stop light.
Any input why or what i could do?
- Wrong Timing Advance?
- I have the Engine knocking under Load with 18 Degree @ 1200 Rpm (Base Timing) so more Advance aint the way.
As i didn`t had a Cam Card for the Camshaft (only a small Sticker on the Box), i set the Timing Chain to 0 Degree durring installation
and i didnt "Degree" anything.
Question:
Can i check if the Timing Gears / Chain degreeing is wrong if i go on TDC and use Air pressure thru Sparkplug of Cylinder Nr.1 with a valve Lifter Air Tool.
If the Pressure doesn`t build up (or stays) on TDC the valves aint closed, so i could turn the Crankshaft (BTDC o ATDC) and read the degree from the Balancer Scale. Right or totally wrong? So this would be the amount of Degree that would need to be Advanced or Retarded at the Timing Chain.
or could it be the additional holes on the Butterflys of the Edelbrock AVS2 (1906) 650 CFM (+ Tuning Additional 0.04" Holes on all 4 Throttle Pates)
Thanks for all your help
Greetings
Nic
Facts First:
Timing:
Problem:
Question:
Greetings
Nic
