Posi units
8.5 10 bolt has some of the best optional posi units out on the market.
EATON tradition performance LSD clutch type is the most popular choice anbd a good one
- the posi has been re-manufactured by many copies now so be careful on the brand name you get.
-there are Summit brand, Jegs Brand, Everyone in the Internet has repoped them. so they are assemble by anything and everything....lol. BE CAREFUL
stick with a good brand name...We use Yukon for all our build and come with a 1 year manufactures Warranty and I think in 20-25 years we used warranty ONCE...lol. Good stuff. CAn not usually go wrong with Actual EATON brand name the inventor and designer of the unit...
AUBURN Again a traditional friction base posi unit.
-were Originally used in Muscle car era cars like Buick Olds and Pontiac...Mopar even had them in the 8.75 popular MUSCLE car rears from 69-78 era.
-Cone unit hook very well ...done side they usually are NOT rebuildable with out machine work that a regular back yard guy can not do with out VERY expensive machinery.
These and Eaton unit still should last many years of driving like 15- 20 years with out issues.
TRUE Trac - Torsen Worm gear posi units
-Becoming very popular these days ...most Foreign and imports come with these forms of initial Helical gear to gear type multi biasing units.
-People like they because generally there is not maintenance to the unit...BUT I guarantee they WILL WEAR out like any other unit...Just might be in the more violent total LOCK up way when it finally does happen. TRUE TRAC has a hardened case as the WORM gears need a strong hole that will not oblong over years of use. This give the unit a strong ability to plant power to the ground and torque sensing ability to delivery the power as much as it can in turns until friction is lost between the tire and ground. True trac will also give you another slight side to to slide gear contact point again for strength.
Auburn had this also with the 4 pinion posi unit which was and great increase from the traditional 2 pinion spider gear unit.
GM AUTO LOCKER (also nick named the GOV LOCKER)
This is a great unit for a everyday none performance driving car or truck....IT IS NOT A PERFORMANCE UNIT.
Meaning for burn outs and cornering spirited driving muscle car...IT IS NOT A GOOD CHOICE. It is a low speed operational unit ...30 MPH and under is the lock up point of these units. OVER 30mph it does not lock. Best not to make this choice for a Burn out or drag race machine.
DETROIT LOCKER Legendary locker...extreme application unit...Not street friendly,. Clunky around corners...normally used for OFF ROAD machines not drag racing and corner carving up mountain hills on the pavement. EXPENSIVE and all heck too.
LUNCH BOX LOCKERS (power trax, lock right, Spartan locker, maxx traxx, ) All are posi unit derived from the Detroit locker design but easy install with out gear ratio or carrier swap makes this unit convenient, easy, fun, strong unit AS LONG AS YOU READ THE DIRECTIONS and install correctly. This unit has one of the worst records for WRONG install by customer just plain getting them install wrong...lol they do work well and can be great money spent.... We have used and installed many for weekend warriors here in Ohio The unit will have a tapping noise in turns and hooks hard in straight aways. Follow the instructions to the T and you will love it. DO NOT you will have headaches!
SPOOL MINI SPOOL Well these I would say are for either DRAG RACE ONLY or VERY low buck application where you rolling the dice...lol.
Full spool will require BOLT IN AXLES (factory BOP or C-clip eliminator for chevy c-clip rears.
Mini Spool can be used in either or... BUT really is not supposed to be a street driven unit as it is just blocks that stack in the place of the open spider gear cavity when spiders are removed. MINI SPOOL is dangerous and I personally HAVE used them on the street in my younger days...and did not have any issues. They do not last for ever the blocks will beat them selves and the case up after a while 3-4 years of street driving if you do not break something else first...lol axle shafts tire wear etc. high strain on axles around corners. Terrible in weather like rain and snow...lol. NO sensing of traction at all IT IS ALL or nothing...
Any way those are some of the different designs out there just read and google people opinion and be smart...try to pick something that fits your price range and driving techniques / terrains / conditions your going to see when driving .
Again some of the info is opinion and not all fact... I am just trying to help you the buyer make a good decision from my personal experiences too.
Safe driving to you and your families.
