10 bolt 8.5 g-body 78-88 monte carlo GN 442 Malibu 3.73 POSI
all new build
10 bolt 8.5 J D Race housing rear end
specs
10 bolt 8.5 housing blasted and painted
3.73 New Yukon performance brand gears
New Auburn High Performance 30 spline posi unit
All New bearings and seals
New Moser 30 spline axle shafts
New Upper Double adjustable control arms
New Msoer Aluminum girdle cover
Direct replacement for any 78-88 G-body Gm Chassis (same as GN or 442 84-87 )
1795.00 Spring sale add up the parts all these parts are new and the housing is the same exact width as your existing 8.5 or 7.5 rear your brakes will bolt right up also to same you more time and money.
Shipping is always available just ask for a quote PM we need your zip code for this quote
