Opinions/Parts
Posted: Mon Feb 27, 2017 3:24 pm
Looking for some advice/recommendations. I have a 1972 Rivera with the stock 2:93 rearend. I was able to purchase a posi rearend from a 1973 that has the same gear ratio, last year on craigslist. So, I have two rear ends, the stock "open" carrier and a posi, both with the same gears. My first thing I would like some opinions on is, is this worth the effort of changing them out, just to obtain a posi?
To help with your opinion, the car has 70,000 original miles. It is completely stock currently. My restoration is a very "slow as I go" process. When I get to the point to pull out the engine and do a "refresh", I won't be looking for anything crazy. I will end up with around 450 to 500 HP when I am done. Normal driving for this car, is just to local car shows, charitys, etc.. I am not looking to race it and the 2:93 gears, at least for me, seems good for the better cruising mileage. The beast will easily break the tire loose from a hard start currently. So, my hope was to just be able to put more power to the ground (less spin) out of the hole, but yet still maintain reasonable rpm's on a cruise. I know how difficult it is to find the "unobtainium" 3:42 rear end from these years. And, even if I could find one, I would probably consider eventually installing a Gear Vendors unit to get the best of both worlds. Besides maintaining cruise rpm's, the other advantage I have is that, with both units being the same gear ratio, I would have a spare set, in the unlikely event of damaging one set, at some point.
With all this, any thoughts or ideas are welcome and appreciated in advance. If I do go ahead and switch these out, I would like to obtain a complete rebuild kit, if possible. I have seen on this site, all of the bearings and races for the diff and pinion. But, what about the wear components inside the carrier? Clutches, s-spring, etc... I have recently replaced the axle bearings and seals, so those wouldn't be needed.
Again, any opinions and advice are appreciated. Thank you!
