Hello from New Zealand
Posted: Tue Jun 09, 2015 11:30 pm
by muzzy
HI, New user from NZ,rebuilding the rear axle on my 69 Camaro with ring & pinion I got form Jim.
Hoping to get some advice regarding reassembly, gear pattern and condition of the clutch pack in the posi.
Regards Muzzy
Re: Hello from New Zealand
Posted: Wed Jun 10, 2015 12:12 am
Muzzy good to see you here and hoping to help you and other understand more of building the rear differential parts with and with out proper tools.
Posted: Wed Jun 10, 2015 12:14 am
Make sure to use the differential section to ask the questions.
Posted: Wed Jun 10, 2015 12:16 am
by muzzy
Yep,sure will Jim,I will have to learn to post pics
Posted: Wed Jun 10, 2015 9:57 am
Pretty easy on this sight. Upload Attachment (under the subject WINDOW highlighted in grey) will get it done and you can browse your computer for the picture select the picture and it will be saved on this site. IF you want up loads to go quicker resize your pictures to web size... Your camera or phone should have a setting to do this also LESS resolution and or pixels. Ok? Jim
