Which axle to rebuild?
Posted: Wed Mar 20, 2013 10:54 am
by pontiacman63383
Ive got a 69 custom s that im going to put a new rearend under but im not sure which i want to use. Ive got a 69 and 72 gto rear end. the 69 has the sealed bearings and the 72 has the bearings with external seals. Ill be doing a complet rebuild on one of them but im not sure which one yet. Is one set up better then the other when it comes to the seals? Is one set up stronger then the other? Also the 72 carrier is a posi and id like to use it so will it fit into the 69 axle if i decide to go that route? It there about the same im going to go with the 69 as its in a little better shape so it will be less work to clean up and paint.
Re: Which axle to rebuild?
Posted: Fri Mar 22, 2013 10:02 am
Ok, Well it really is a toss up.
If you are looking for a better exterior and the car is clean would go with the cleaner housing.
NOW If you are reusing the gears and posi do the 1972 housing as that is the housing all the parts are already set-up in and will save you the labor of the set-up of NEW gears which will be costly. YOU can just disassemble and reassemble the rear with all the 72 parts and only have to worry about pinion preload and double check backlash then your done.
Another thing to check. 1970 -1972 all GTO and other GM 8.2 and 8.5 rears started using larger 7/16 bolts and left hand thread ring gear bolts. This causes trouble swapping a 7/16" ring gear bolt posi into older and or NEW ring gear 3/8" smaller bolts to the posi as the holes will be TOO BIG in the posi and the ring gear will slip on the ring gear mounting flange...NOT GOOD. We do sell sleeves to solve this problem. that will fill the spacer around the 3/8" bolt so it fits the 7/16" holes.
So axle bearings are about the same price. Type of bearing ...sealed bearings are usually trouble free for 30K miles easy Oiled bearing are supposed to be slightly better in performance and longevity...Flip a Coin in my opinion for as much driving we do with muscle cars either will be fine.
Housing will be the same strength factor so that is a even comparison.
MAny be post pictures to be sure they are what you think they are. Jim
