confusion on a hbody differential
Posted: Tue Feb 26, 2013 2:57 pm
Just have some question on a hbody I just purchasd.
It is an H body differential with 5 lug s10 axles, it is I believe 2.93 gear. So I guess my question is. Would the ring and pinion have to be for/from the vega differential? I cant find where this gear was used in the other hbodys. I was told it was a 2.93 and it looks like it is according to turning the drive shaft with the wheel trick. Its just short of 3 turns on the driveshaft.
The car also has the 4 cyl saginaw which has the steep 3.50 1st gear. The car has no traction in 1st or 2nd. Would it be wise to change the rear gear ratio to a 2.73? Im already getting traction bars so I figured the slightly higher gear plus the bars would help quite a bit. Not really wanting to change trannys right now and the gas mileage would be a little better also. Down the road I will be getting a different tranny and then will drop the gear again to prob 3.23. Ive read that the hbody housing could be modified to fit a larger g or f body pinion. What is the spline count on a hbody pinion?
Bill
Bill
