spider gears
Posted: Thu Jan 10, 2013 8:39 pm
by mjol
Hello Jim.
Can I use the spider gear thrust washers [small spiders ] off an 8.2 open carrier on an 8.5 posi??
I am preping an 8.5 # 409 carrier and found these thrust washers missing.. If not , how much do you want for just the small thrust washers with shipping to 92584 ??
Thanks, Mike
Re: spider gears
Posted: Fri Jan 11, 2013 2:07 pm
No the diameter for the inner cross pins are different. You can use 8.5 OPEN differential thrust washers to do the job just not 8.2 10 bolt.
7.50 will get you 2 thrust washers and shipping to CA
