El Camino 10 bolt into 70 Pontiac
Posted: Thu Dec 13, 2012 12:17 pm
by KiwiGT-37
Hey there,I've totally smashed the 10 bolt in my 1970 Pontiac GT-37,(same as GTO)a mate of mine has a complete drum to drum 10 bolt from his 70 El Camino,could you tell me please if this unit will bolt straight up to my Ponty.
Cheers
Re: El Camino 10 bolt into 70 Pontiac
Posted: Thu Dec 13, 2012 11:32 pm
The entire rear will bolt right into the chassis. Only thing you might need...is a u-joint. to convert the drive shaft to the rear end yoke.
Part numbers are - conversion joint precision 372 / neapco 3-3130 / spicer 5-3022X
You should not need anything else. brakes will be the same except for the drum pilot hole chevy has a 2.81 while the pontiac has 2.771.
That should do it.
Guts are different and need to stay with there original housings.
Posted: Thu Dec 13, 2012 11:49 pm
by KiwiGT-37
Thanx heaps for that,I'll have to see if those parts are available in NZ
Posted: Fri Dec 14, 2012 12:54 am
I am sure they are. It is called a chevy to BOP conversion u-joint.
If you can not get it PM me will ship it over no problem.
