Does size count
Posted: Tue Dec 11, 2012 12:35 pm
by mjol
Good morning Jim.
Do I need longer left hand thread bolts if using a spacer with a "2" series carrier and 3:42 gears on an 8.5 set up?? If so, do you sell them and how much.......... Thanks, Mike
Re: Does size count
Posted: Tue Dec 11, 2012 5:01 pm
OH YES ABSOLUTELY!!!! That is the only reason spacers fail. Where did you get the spacer from?
WE always sell them with the bolts and lock tight. Jim
I wil lsee if I just have a set- of bolts might be about 20.00 and some shipping 24.00 total ish.
Re: size does count
Posted: Tue Dec 11, 2012 6:10 pm
by mjol
Hi Jim.
I had two spacers hanging on the wall, both being .250 I do not recall where they came from, but they came with extra shims but no bolts. Your price is fine, so let me know or call 951-265-8646............... Thanks for everything, you are the best.............
Merry Christmas................. Mike
Re: Does size count
Posted: Tue Dec 11, 2012 8:15 pm
Before doing that you need to know that the .200 is for a 8.5 those may be too thick./ Measure the ring gear bolt holes drilled in them. IF they are 3/8" they are chevy 8.2 ring gear spacers and they will be too thick moving the ring too close to the pinion making it impossible to set the ring and pinion correctly with shims. Jim
Re: Does size count
Posted: Tue Dec 11, 2012 8:47 pm
by mjol
Jim.
Definately .250, the 7/16 bolts I have are a tight fit, but they do fit, I have the option of having these milled to .200 if you say that is what I should do..... How much is the correct spacer and bolts through you ??? Thanks, Mike
Re: Does size count
Posted: Wed Dec 12, 2012 7:29 am
45.00 50.00 shipped. LET me measure to be absolutely sure before jumping. Jim
Re: Does size count
Posted: Wed Dec 12, 2012 9:08 pm
by mjol
When you let me know the specs, I will pull the trigger on the deal, if paypal is the option on paying, please let me know your paypal address. Thanks, Mike
Re: Does size count
Posted: Thu Dec 13, 2012 11:43 pm
Rats, Forgot to get those measurements. Jim
Tomorrow.
Sorry
Re: Does size count
Posted: Mon Dec 17, 2012 8:43 am
.210 is the thickness. Have the bolts and kit...Last one.
Re: Does size count
Posted: Mon Dec 17, 2012 11:31 am
by mjol
Send me a paypal address and I'll pull the trigger... Thanks and Merry Christmas..... Mike
Re: Does size count
Posted: Wed Dec 19, 2012 7:46 am
You need to PM me that info. I do not have your email. Jim
