8.8 FORD G-BODY STREET STRIP MOSER AXLE SUPER REAR
Posted: Thu Oct 11, 2012 8:13 am
10 BOLT 8.8 FORD STREET STRIP 3.73 POSI REAR END FOR G-BODY
FITS ALL 1978-1988 G-BODY CHASSIS GM CARS
MONTE CARLO, CUTLASS, GRAND PRIX, MALIBU, REGAL ETC.
CUSTOM 8.8 JD RACE HOUSING NARROWED TO G-BODY WIDTH
-52.25 FLANGE TO FLANGE AND OR 58" DRUM TO DRUM OVER ALL WIDTH
MEDIA BLASTED PRIMED AND PAINTED HOUSING
MOSER 7900 BILLET END TO USE GM BRAKES AND FORD LARGE BOLT IN AXLE BEARINGS (C-CLIP ELIMINATED)
MOSER CUSTOM RACE AXLES 31 SPLINE FOR SANCTIONED RACING IF NEEDED
-5 ON 4.75
-1/2 X 20 X 3" SCREW IN STUDS
-STANDARD GM BRAKES AND AFTERMARKET DISCS CAN BE USED ON THIS REAR
-BIG FORD BEARINGS FOR THE STRONGEST AXLE RETENTION AND LONGEVITY
3.73 8.8 RING AND PINION
PERFORMANCE 31 SPLINE TRAC LOCK UNIT INSTALLED FOR POSITIVE GRIP TO THE ROAD
-FULL SPOOL CAN BE SWAPPED FOR NO EXTRA CHARGE FOR ALL OUT RACING
-JD RACE DOUBLE ADJUSTABLE UPPER CONTROL ARMS CAN BE INCLUDED TO MAKE THIS A DIRECT NO MOD BOLT IN.
PROMOTIONAL PRICE - 1499.00
WITH J D RACE UPPER CONTROL ARMS 1599.00
THIS IS A NORMALLY 1800.00 SELLING REAR...PLEASE TRY IT AND TELL A FRIEND!
ACTUAL REAR END PICTURED....
-5 ON 4.75
