Spring Perches
Posted: Thu Sep 06, 2012 4:21 pm
by 71MONTE4YA
Hey Jim!! Can I use these perches on my BOP 12 bolt rear? The previous owner that I bought the rear end from moved the perches on top of the housing to put it in a g-body regal.
Re: Spring Perches
Posted: Thu Sep 06, 2012 8:39 pm
Yes i believe you can as long as they hang off the front of the axle tube and they are NOT to high . The bottom of the spring should be even with the top of the axle tube. Jim
Re: Spring Perches
Posted: Fri Sep 07, 2012 10:29 pm
by 71MONTE4YA
Thank you very much Jim!!!... Rodney
Re: Spring Perches
Posted: Sat Sep 08, 2012 7:47 pm
If you can get those perches off you can even use them...Hang them off the front and put some lower support gussets and be done.
