Carriers and Gears
Posted: Fri Apr 06, 2012 8:43 am
by 69Yellowvert
I have been reading through the forum posts trying to get a little smarter and I think I am getting more confused. From what I have seen about the different carrier series if you want to use numerically higher gears (i.e. 4.11) on a 1 or 2 series carrier you will have to use a spacer to get the correct alignment. How does the relationship work for using numerically lower gears (i.e. 2.78) on a 2 or 3 series carrier? I am just trying to figure out the options I will have available when I go to change out my open carrier for a posi.
Steve
Re: Carriers and Gears
Posted: Fri Apr 06, 2012 12:55 pm
YOU can not go backwards If you have 4.11 on a 4 series carrier YOUR STUCK...You will HAVE to buy a the 3 series or 2 series you need
You can ALWAYS spacer to a STEEPER gears BUT you can not go in reverse on the ratio.
SOMETIMES- Works can not explain as well as in person. If you are still lost please do not hesitate to call and will try to help you understand better.
330 990 8155
Posted: Fri Apr 06, 2012 4:59 pm
by 69Yellowvert
Thanks Jim I will give you a call tomorrow and you can make me smarter. Seeing the carrier breaks definately helped, but I would like to pick you brain some more.
Thanks Again
Steve
Posted: Sat Apr 07, 2012 1:01 pm
Yep, No Problem. Sometimes seeing helps a lot. Jim
